D.o.d. Cam swap
Old 01-09-2010, 12:00 PM
Mrgoodwrench3's Avatar
Originally Posted by Midnightrider
throw those dod junk lifters in the trash and put LS7 lifters in also change out you valley cover. I would go prc duals for springs instead of 918s
Why do you say the DOD lifters are junk? What has your experience been?
Old 01-24-2010, 10:37 AM
gblauf's Avatar
I just put a 3 bolt comp thumpr cam in my 08 5.3. I bought the 06 vette cam gear. It was $22 at my local dealer. make sure you get the one with 4sensor bumps. This is for the cam sensor. Autozone offered a cam gear for an 06 vette but it only only had 2x sensors. Truck ran like crap! I did not run the tensioner. You will get 50% of gearheads say you need to and others say you dont. You must remove oil pump to get to the tensioner. I hear removing the oil pump is a pain in the *** and alot of people screw it up! I have 4000 miles and no problems so far.
CAM GEAR part gm# 12586481
Search the trailblazer forums as well, there is a ton of info on this subject.
gb
Old 01-24-2010, 11:36 AM
I am going to replace the timing chain with an IWIS so the oil pump will be off anyway. I called Thunder Racing and they told me the TR224 is too much cam for a 5.3. He recommended the TR220. Then you can run a 2800 converter.
OHsixLS3
12-27-2016 09:30 AM
GrooveCityZ71
08-31-2015 12:05 PM
WICK3DxGATA
07-21-2015 06:59 PM
Aboss
07-09-2015 10:28 AM
GreyChevy
07-07-2015 08:57 PM
Quick Reply: D.o.d. Cam swap
