daytona prototype motor in a truck
Old 02-16-2008, 05:39 PM
IMD
Banned
IMD's Avatar
Originally Posted by jkwalkercchs
imd---i think outside the box try it some time
thats great, try thinking outside the crack pipe instead.
Old 02-16-2008, 05:48 PM
Mr. Obvious
nightrunner's Avatar
in the usable rpm range, a ****** honda will make more torque than that motor. there IS a reason no one has used that motor yet. that motor is setup to be run at very high rpms constantly, as in a road racing application
Old 02-16-2008, 06:00 PM
jkwalkercchs's Avatar
crack does the body good
yea i know but i wanna a high revvin truck
ill just drive it around like im racing
Old 02-16-2008, 06:06 PM
Mr. Obvious
then go ahead and do the build. and then the entire forum will laugh at you when you complain about spending money on a engine build and it doesnt make any power before 5krpms and takes more maintenance than an full blown dragster. there is a reason that no body on here daily drives a truck with a solid roller valvetrain.
Old 02-16-2008, 06:12 PM
no my daily driver is now a sportster 1200 custom
whats the diff in this and a 4.8 turbocharged?
Old 02-16-2008, 06:20 PM
Mr. Obvious
a 4.8 turbocharged, if a quality turbo kit is used, will maintain stock reliability, and with a properly sized turbo, start spooling at approx 2500 rpm and have full boost at 3500rpm and be MUCH faster than your proposed NA setup and get MUCH better fuel economy
Old 02-16-2008, 06:22 PM
did u miss the post i made about i wanna go turbo???
Old 02-16-2008, 06:23 PM
IMD
Banned
IMD's Avatar
ahh a sportster. that explains alot.
Old 02-16-2008, 06:25 PM
whats wrong with sportster??
Old 02-16-2008, 06:29 PM
Mr. Obvious
i did miss that part BUT, what is the point in revving so high when you have a turbo? i dont remember the exact problems but i have read about having problems when revving over 7krpm when FI is used. maybe problems with getting valve springs to support the presures and not let the valves float. also for much boost you will need down to around 9:1 or lower. also forget about a solid roller with a turbo
Quick Reply: daytona prototype motor in a truck
