daytona prototype motor in a truck
Mr. Obvious
then go ahead and do the build. and then the entire forum will laugh at you when you complain about spending money on a engine build and it doesnt make any power before 5krpms and takes more maintenance than an full blown dragster. there is a reason that no body on here daily drives a truck with a solid roller valvetrain.
Mr. Obvious
i did miss that part BUT, what is the point in revving so high when you have a turbo? i dont remember the exact problems but i have read about having problems when revving over 7krpm when FI is used. maybe problems with getting valve springs to support the presures and not let the valves float. also for much boost you will need down to around 9:1 or lower. also forget about a solid roller with a turbo
