differance between 112 over 112+4 lsa
Old 06-24-2009 | 02:19 PM
  #31
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by twolow02fransen
man didnt think this thread would be such a big deal jeez so whos right and whos wrong
Basically we need to see your cam card .
Most likely that 112+4 is a 108ICL and a 112LSA
Old 06-24-2009 | 05:37 PM
  #32
05HD1500's Avatar
stupid question and im not goin to buy the one that sounds better ok my buddy has a 224/581 on a 112+4 in a 05 5.3 LTs ory yada yada but my question is the truck sounds very timid at idle ive heard a 220/581 on a 112 and it sounded meaner at idle does the 112+4 mean it has 4 degrees advance ground into the cam and is that the reason it sounds timid ?
so back to the original ? yes the +4 means it has 4* advance ground in. but it not the reason it sounds timid. Due to the larger duration and same LSA the "Timid" cam has more overlap and should theoretically have a choppier idle, which, i assume points to the tune. unless the engine size were different like the small one in a 4.8 and the big one in a 6.0. A large motor will make a large cam seem smaller...
Old 06-24-2009 | 09:40 PM
  #33
I AM A MOTHERF*CKER
We really need to see the cam cards. You can't tell one cam from the OP's post has more overlap or not from what was given. It's theoretically possible for the 220 intake 112 cam to have gobs more overlap that a 224 intake 112+4 cam...
E.g. a 224/208 112+4 which could have 35* overlap vs a 220/230 112 which could have around 54* of overlap.
There's just no way to guess without knowing the exhaust side (and even then it would just be a guess without the actual valve events for the lobes).
Old 06-24-2009 | 11:02 PM
  #34
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
well id be more then happy to show you the specs but its not even my cam its in my buddys truck but i do know that MTI makes the cam if that helps any
Old 06-25-2009 | 12:16 AM
  #35
I AM A MOTHERF*CKER
Post 'em up
Old 05-29-2011 | 09:12 PM
  #36
2doorfury's Avatar
heres a question..if i were to do a turbo setup..what would be the best for it..+2 or +4?? i seen in a previous post were one of them made less cylinder pressure, and also has more top end power...and the other opposite..i was thinking a cam with more low end would be best since you could have a bottom end power advantage and that could possibly make up for turbo lag?? im kinda new at this gasser stuff( diehard diesel guy, commin over to the gasser side) but im looking for the best power setup, not sound.
Old 05-31-2011 | 10:25 PM
  #37
damn talk about post digging lol forgot about this thread. if it were me id just do a custom grind from PAT G or EPS then you will get what you need imo.
Go5.3tt06
25
09-04-2016 11:25 AM
zblee
11-11-2015 01:41 AM
LARRY01Z28
28
09-28-2015 08:54 AM
Roody0209
09-17-2015 10:06 AM
bisqikss
09-08-2015 04:35 AM
