Different Cam Profile
Old 05-02-2010, 10:39 AM
SweetS10V8's Avatar
Originally Posted by sierra69
Awesome! You gave me alot of info about my future mods.what are you running?
6.0L LQ9
Lingenfelter CNC L92 heads w/ GM LS3 lightweight valves
Comp 219/235 .607/.621 113+5 Cam
Comp 918 springs w/ tool steel retainers (<1g heavier than titanium, but doenst wear away)
FAST LSXR 102mm Intake
GM 90mm LS2 TB
Comp .105 wall pushrods
1 3/4" longtubes
3" dual mandrel bent exhaust
Comp 850-16 lifters
25% UD pulley
Stock rockers with Comp trunion upgrade (everyone should do this)
I really like that FAST LSXR 102mm intake...maybe some day...
LSXR or LSXRT? The RT should make more power than the LSXR.
Old 05-02-2010, 05:52 PM
11 Second Truck Club
MPFD's Avatar
I have the new patriot cam and its pretty good. I would have actually liked to have gotten the cam you have when I bought mine, but they had stopped making it. Gunner told me that the new cam made about the same power but idle'd better and was easier to tune for. My cam sounds good at idle and makes great power so I'm happy with it. I have a "BIG" cam sitting in the closet waiting to go in, but it will probably have to wait a little while. At least till I get a gear...
Old 05-03-2010, 09:58 PM
PT's Slowest Truck
budhayes3's Avatar
The taller one of the two...would that be the "T"? Is the "T" for "truck" or am I totally off?...
Old 05-04-2010, 08:16 AM
Preston129's Avatar
The "T" version is the taller one. In FAST's literature, they say it's designed for trucks and cathedral-port headed cars with hood clearance. I think the only reason we don't see more of them is they just don't fit under a gen-4 fbody hood.
Old 05-08-2010, 06:16 PM
formerly ByuTrukFreak
ByuTrukr's Avatar
That intake sure is awesome looking, i wouldn't mind having that, I still run the stock truck intake.The 223/231* .610/.617 112 cam looks good too. But I'm kinda scared to go that much lift with the Patriot heads, the springs are supposed to be good to.650 lift, but I had some Comp R lifters(Which I'm still running) and Pro Magnum roller rockers with 1.75 ratio and I had valve train problems, instability so I was told. I figured the lift was .602 with those rockers, I put the stock rockers back on and my problem was gone. Anyone using Patriots 5.3 heads with that much lift have any problems.
Old 07-09-2010, 08:49 PM
ByuTrukr's Avatar
I think it's because it's too expensive.
Dan Neumann
11
08-07-2022 09:06 AM
Greatdivider
09-09-2015 09:52 AM
steves86ta
07-28-2015 10:21 AM
bgray
07-23-2015 10:56 AM
Atomic
07-22-2015 03:41 PM
Quick Reply: Different Cam Profile
