dry sump in a truck
im considering running a dry sump in my 427 lsx twin turbo. ive been chatting with katech about running the oil squirters. they are concerned that even with a high volume pump that it may not be enough with a wet sump and the stock oil pan. with running the turbos , the squirters and engine its alot of demand . so im considering a dry sump setup . im just concerned on oil pan , clearance and other room for the dry sump reservoir etc i know its not 100% necessary being my truck wont see hard cornering but will see some har launches . any advice?
yeah i know i have more room the a c6 but after the turbos and all it will be getting down there.
as for tuning , depends ill do some of it and have justin help me with the fine tuning.
I have seen dry setups in person, and the tank is usually a 1 to 1 1/2 gallons, and it needs to be mounted barely above the pump.
So if you look around in your engine compartment you should be able to find a place in back the can hold a milk jug sized container.
Suburban2500
07-19-2015 04:50 PM
Mossyoakglock
07-17-2015 08:30 AM
Nimoryan
07-05-2015 03:50 PM
