Which is easier??
Unfortunately, no, it is completely manual. ![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
If I were to get a Gear Vendors OD it would only be to have a 5th gear (overdrive after 4th runs out of steam). Even then, you would have to engage it manually with a switch. It would be a total PITA to use it on a daily basis in between all of the other gears.
For my purposes it would be fine. I would give me all the strength I would need (i.e. Level 5 4L80E + GV OD, which is good to 1200 or 1500 HP/TQ I believe), and an extra gear so I could dive down into a lower rear-end gear like 4.10's or 4.56's.
That way, I could get neck-snapping TQ off the line without having to resort to a loose TC, and still get optimum cruising RPM/mileage at speed. I did the math once and with my tire combo, 4.56's, a 4L80E, and GV OD unit, came up with 1800 RPM at 75 mph. That's the sweet spot for mileage.
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
The Gear Vendor unit is nice except for the fact that it's $3500! I'm almost positive they have a stand alone controller that makes it fully automatic now. I looked into it but they don't have a unit that works with the AWD.
US Gear has a cheaper version of a OD, but you have to set it before you get above 30mph.
It works fine for just towing or whatever, but lacks some of the coolness of GV's.
06murder
09-04-2015 03:54 PM
