View Poll Results: Who should tear apart my mistake
Voters: 12. You may not vote on this poll
Engine tear down DIY or Shop?
Just now getting to my 6.0 that I think I spun a bearing or had a lifter fail. Should have it out next week and I'm torn between tearing it apart myself to find the point of failure or just taking the entire thing to a machine shop and have them disassemble it since they will be the ones rebuilding it. Kinda seems like a stupid question but I'd like to know for sure what the point of failure is since its likely my fault. I had planned to disassemble it myself but a few bromigos told me to just let the shop do it.
Depends on your work load and income. Also in my case age and pain lol.
dantheman1540 (06-25-2020)
Time is not an issue I'm going to take it slower this time.
Money (within reason) is not an issue if there is a benefit to the new rebuild. Not sure what that would be exactly.
Physical ability is not an issue but mental capacity might be
![Dewey](https://www.performancetrucks.net/forums/images/smilies/smileyugly-man-laugh.gif)
Do it yourself. Take pictures, keep everything in order, document what's there, etc.; so that whatever info is contained in it, is preserved. But by doing it yourself, YOU know what's messed up (or not, up to a point) and can discuss intelligently with your machinist what you want done. Do it slowly and meticulously so you don't miss anything.
Do half of it yourself. I pulled mine apart, took the block and rotating assembly to the shop, had them clean and inspect everything and assemble the rotating assembly then did everything else myself. I have a lot of tools and know how, but there is some stuff best left to a good engine shop.
The following 2 users liked this post by firebladeJJ:
A4edwin (02-01-2022),
Thanks for the responses
I think I will end up doing it myself, seems as though there's no real benefit to having them do it. I'll be sending them everything I think is salvageable anyway, I hope the block and heads are alright.
