View Poll Results: Who should tear apart my mistake
Me
41.67%
The machine shop
8.33%
Put it back together and dump the clutch
50.00%
Voters: 12. You may not vote on this poll
Engine tear down DIY or Shop?
Old 06-29-2020, 10:03 PM
  #21
dantheman1540's Avatar
Machine shop owner found the oil consumption culprit in less than 5 minutes before we even unloaded anything. Turns out the oil scraper rings were 2.5mm instead of the required 3mm. It explains why I ended up bending one and having to get a replacement when I initially assembled the bottom end. I got the rings from the previous shop that went out of business suddenly weeks after I picked my stuff up.
Oh well lesson learned do more research and learn what's what don't just put full trust into someone taking your money.
New shop is still going clean everything do a full inspection and plan to bore to a 370 with forged pistons but gen 4 rods and crank. He said from initial inspection everything looked good to reuse such as pushrods, cam, lifters, timing set, rocker arms with CHE upgrade, and all arp bolts/studs. He called JE pistons while I was there and they recommended part# 360991 which should net about a 9.6-1 comp ratio. I don't mind a little loss in comp just to keep it happy on pump gas and to give me more threshold for knock. Not shooting for records just a fun daily driver tire smoker.
tjmath (06-30-2020)
Old 06-29-2020, 10:13 PM
  #22
arthursc2's Avatar
Received 1,444 Likes on 1,068 Posts
Dump da clutch!
Old 06-30-2020, 03:57 PM
  #23
Custm2500's Rude Friend
1FastBrick's Avatar
You never showed us any pictures of the pistons out of the block or the rings.... but it does make senses...
Sounds like a couple of clutch dumps will get you fixed right up!!!
Old 06-30-2020, 05:14 PM
  #24
RB04Av's Avatar
clutch dumps
Am I detecting some sort of OCD here???
Old 06-30-2020, 05:28 PM
  #25
1FastBrick's Avatar
Talking
It's a know fact he is a Filthy Clutch Dumper...
Nothing makes him happier than dumping the clutch in something...
Old 07-01-2020, 07:28 AM
  #26
[QUOTE=1FastBrick;5485261]You never showed us any pictures of the pistons out of the block or the rings.... but it does make senses...QUOTE]
I honestly didn't take any pictures of them because I thought they looked great and once I got to the shop it was hot and I wanted to dump the stuff off and leave. I could have probably just re-ringed the same pistons slammed it back together and got back to clutch dumping but the cast pistons have kinda bothered me since the beginning and I wanted to have everything triple checked to ensure there weren't other unseen problems.
Heres some picture proof of my love for the clutch dumping.
Cadillac Edd
11
04-19-2018 08:31 PM
Cammed4ever
11
08-25-2014 07:14 PM
thomasblack
11-03-2010 07:00 PM
Atomic
61
06-22-2010 01:03 PM
Tootall
12-07-2006 08:52 PM
Quick Reply: Engine tear down DIY or Shop?
