Eps 222/226 cam
I am running the EPS Truck Torque 2 in my truck.
2007 5.3, ported 799's, Ferrea valves, 5 angle, 3000 converter.
It pulls really strong through the entire rpm range.
Truck Torque 2
Product Information
Intake Duration: 218 Degrees at .050" Tappet Lift.
Intake Lift: .595" with 1.7 rockers.
Exhaust Duration 226 Degrees at .050" Tappet Lift
Exhaust Lift .598" with 1.7 rockers.
113 Degree LSA
Truck Torque 2
Product Information
113 Degree LSA
13 Second Truck Club
Truck Torque 2
Product Information
113 Degree LSA
Truck Torque 2
Product Information
113 Degree LSA
what rpm you shift at?
224/230 .610/.605 on a 111lsa +2
LT's, 65e, 3.73s, trutrac, intake, 31lbrs, and tune. It runs great.
Considering i went from a V6, to this. I haven't had time for dyno/track numbers yet. Just a few mexico runs. Im not complaining one bit. You'll like the eps cam. Do some searching on ls1tech. Those guys are putting great power and times with small-mild cams. Plus the eps lobes supposedly aren't as hard on the valvetrain.
Hope that helps
This is from EPS's site:
http://www.engpwrsys.com/tech-notes/cam-design.html
Rick
I got the EPS/Comp cam custom grind , 226/230 .589/.600 113+2. I haven't got it in yet but I like what I'm hearing about it so far. It seems more people are going for 113 LSA, looking for a wider power band.
