Ev Volumetric Efficiency
Old 05-05-2006 | 10:29 AM
jm's customs's Avatar
Default (HELP)Ev Volumetric Efficiency
can anyone tell me what the volumetric efficiency is for the 5.3 or how to get it.
Old 05-05-2006 | 11:23 PM
Bowtie70SS's Avatar
I think most street normally aspirated engines come in around 80% or so. A full race engine can be 100%, while top fuel engines can be over 100%...not sure how but just what I've read.
Dave
Old 05-06-2006 | 04:51 PM
AintNoHo's Avatar
VE (volumetric efficiency) is the amount of air used as a percentage of displacement. With a known cfm of air used say 500cfm, displacement say 325ci, and rpm say 6000, the computed VE is 89%. As you see, it will vary with rpm and load, also a 4.8 can have the same VE ratio as an 8.1, just less cfm pushed. Naturally aspirated, the max is 100% although with a tuned intake and exhaust it is possible to get 103% at a specific rpm. Forced induction can have 140% and much more. A VE table is a chart with rpm on one axis and vacuum/boost (or load) on the other axis and is used to compute the amount of fuel for the injectors.
Maybe someone else knows the exact max for a stock 5.3, if that's what you're after.
Old 05-06-2006 | 05:06 PM
AintNoHo's Avatar
Do a google search for performance calculator automotive, it's on a race site (I don't want to name the site) and down load the v.01 perfcalc. It has VE and a lot of other formulas you might like.
Old 05-07-2006 | 05:50 PM
thanks will do
FlowmasterMufflers
10-26-2015 07:19 PM
Rockrz
09-13-2015 01:22 AM
FlowmasterMufflers
08-28-2015 11:58 AM
FlowmasterMufflers
07-22-2015 02:29 PM
