Everyones favorite Game-How Much HP Should this Make?
Lets play the I'm bored on sunday Game LOL
2006 RCSB 4x4 Silvy
03 5.3 block 3.903 bore 9.235 DH
Eagle 4.00 stroke Coated Crank
Eagle 6.125 OL H-beams
Mahle Coated Pistons 11.1:1 with 1mm1mm3mm
ductile top, napier second rings
Custom Cam 220-224 .595lift 112ls 108ilc
LS7 lifters, SB .083 wall P-rods
stock rockers
CNC Ported 5.3 862 Heads SS 2.02in 1.575 valves
210cc intake runner, 300+cfm at .600
Comp 26918 springs,steel retainers
Billit Timing set
New Oil Pump
Massaged Truck Intake, factory 78mm TB,oil pan,ect
SS 1-7/8 Long Tube headers with No Cat Y
Magnaflow Muffler
Yank 2800-3000
4l60Easy with Mods 3.42 G80 rear
CAI system
Full Custom On Dyno Tuning by Wongs
Ok Thats the plan, any HP guesses? Thanks
2006 RCSB 4x4 Silvy
stock rockers
Billit Timing set
New Oil Pump
Magnaflow Muffler
Yank 2800-3000
CAI system
PT's Slowest Truck
*EDIT* Just because there hasn't been a lot of info on here about people hogging out the truck intake doesn't mean that it can't be done though....just means that nobody has really tried it. Now that I think about it, I believe that BlackGMC bought a Dorman intake and did some work on the ports...so I guess that there is some room for improvement
stock bottom 5.3
tr220/220 112lsa
918 springs 5.4 pushrods
fast intake 90-102 t/b
pacesetter l/t with 3'' pipe
42lb injectors
k/n
and may be GENX 205 heads from trick flow
and a tune from nelson..what yall think....possilbe of lil over 400 rwhp?
tr220/220 112lsa
42lb injectors
k/n
