Fuel Pump for 408ci Silverado
Guys,
What is the best in-tank fuel pump for my modified 2000 Silverado Z71?....I built a 408ci (forged) with cnc'd LS6 243s on top, Torquer2 cam, 44lb injectors, and true dual exhaust. I just got it running briefly with a base tune before the O2 sensors (stock) and transmission went bad. Now, while I'm waiting to install the trans, I think the fuel pump is gone...( can't hear it priming when turning the ignition switch)...so....is the Walbro 255 with a harness from Racetronix or Texas Speed the best way to go on this particular GM yr/model?...After marker in-take pumps aren't too common for this vehicle...unless I'm missing something. THanks,
Stroker2112
408ci iron block, Eagle 4"crank, Diamond Pistons, 4340 Rods, cnc'd LS6 243 heads, Trqrv2 cam, 44lb injectors, chromemoly rods, roller rockers, ported pump, true dual LTHeaders w/flowmasters, stock TB/intake.
Stroker2112
Thanks Quik....I notice that most all the Walbros have specific applications listed (Camaro, Firebird, F-Body 92-98, etc...) for their product, but they don't include late model (2000 +) GM trucks....did you just use one of the F-body pumps or did you get something specific/wiring/etc... for your truck (and where did you find it!?)
Thanks,
Stroker2112
Thanks,
Stroker2112
Thanks,
Stroker2112
Thanks,
Stroker2112
reason for cobra pump, needed pump asap and my buddy runs Laurel mountain mustang so he took care of me
5.3lSilverado
25
08-29-2016 01:48 AM
InsaneDomestics
07-27-2015 03:42 PM
Mossyoakglock
07-17-2015 09:30 AM
