Good cam for 5.3 no tq conv
Old 07-13-2010 | 09:02 PM
OH4CHEV's Avatar
Post Good cam for 5.3 no tq conv
Im new to the forum, What is a good cam and valve springs for an 04 5.3 cc without torque converter with 3.73?. Also, anyone have any results torque an horsepower wise that they can post? I am looking to get the snail to move off the line, it runs ok from a roll, I have HP tuners and would probably need to get some help tuning for the cam as well. If anyone has any cams for sell, let me know.
Thanks.
Old 07-13-2010 | 09:07 PM
kazfan30's Avatar
Check out the XR265HR...212/218 .522/.529 114 cam, a solid performer all around. Search the forums for "XR265HR" and look at NicD's results.
Old 07-14-2010 | 09:03 AM
SILVERBIRCH's Avatar
212/218 low lift is a great perfomer i am running this cam in my cc and couldnt be happier with the results and yes it will work very well with stock stall i recomend some ls6 springs with some 7.4 hardened pushrods just for some peace in mind.
Old 07-14-2010 | 01:27 PM
MPFD's Avatar
11 Second Truck Club
If you wanna get off the line you want a converter not a cam...
Old 07-14-2010 | 07:22 PM
white1's Avatar
X2
Old 07-14-2010 | 08:45 PM
006rcsb's Avatar
im looking for the same, i want a cam without having to do a converter, and i have ls6 yellow springs, but i want something that isnt going to lope any at all. i was thinking the vinci ultra torque cam 080 it has a 210/218 duration with 551/551 lift on a 116 lsa
Old 07-14-2010 | 09:48 PM
MPFD's Avatar
LS6 cam...
Old 07-14-2010 | 10:30 PM
Gregory's Avatar
Below is what I have camshaft wise. See the results in my signature. I put it in for towing. Idles nicely at 600 RPM.
208/216 .554”/.561” 114LSA +4 advance (with 1.7 ratio rockers) Comp XE/XE lobes
Old 07-15-2010 | 12:03 AM
grey matter 04's Avatar
13 Second Truck Club
mine does pretty good
even before the stall it was good
Old 07-15-2010 | 01:17 PM
budhayes3's Avatar
PT's Slowest Truck
X3
My baby cam worked great without a converter, and personally I wouldn't go any bigger than my cam without a converter, after driving it both with and without. Down low, it was just a tad better than stock, almost the same, but I only gained 1/10 at the track on my 60' time, which is basically nothing. Now that I have a converter that flashes to about 2900-3k, the truck is so much more fun to drive and launches great (especially in 4wd with traction, in 2wd it just smokes the tires)
