Good cam for 5.3 no tq conv
#31
You're going to love it Matthew...I haven't owned a vehicle with a converter since 99 and forgotten how fun it was to drive. Now that I have one again, I don't know how I survived without it for so long! And just like everybody says, once you get used to it, you want more!
#32
I was/still am, running that cam in my 5.3L and absolutely love it. Works perfect with the stock converter, I'm sure there would be gains with a small converter but definitely not worth changing in a DD. Honestly I don't check the mileage to much but it got 17MPG with a 30min drive both way out to the drag strip, ran two passes, then drove back. Filled up and it got 17 so I would say it's pretty good on gas with the spot on zippy tune I got.
Eventually I'll get all this figured out and actually pull the trigger on something, this will be the first internal mod I've ever done and I'm just trying to get everyone's input on everything.
I think that I am going to use this cam, but I'm going to be looking at something like $1100 when everything is said and done with the cam, springs, pushrods, lifters, and retainers... lol, a 30 dollar LS1 cam started all of this, I have one that I was just going to toss into my 5.3, so I'm a little nervous with my project going from 30 bucks to 1100, so yeah, I'm taking my time.
#34
You may beat me to the punch, and get to tell me how it works out for you. lol
#35
I'd recomend something from the newer LSR line. The Comp Cams 265LrHR12 which is a 215/223 .604/.610 on a 112LSA has been a great cam for 5.3L's. I've recomended that cam for a few 5.3L guys and all have been very happy with the results. Tuning is the big key with it, but that cam makes very good torque and yet still pulls just fine up high with a shift point of around 6200 or so. Here is the spec sheet. http://www.compcams.com/Cam_Specs/Ca...csid=1399&sb=0
#36
Thats's a dang fantastic looking cam and looks like it would work great with a 6spd. My question is, with that kinda lift, would alterations to the cylinder head be needed such as around the seat area to accomodate that kind of lift? Also have reaservations about that tight LSA, I'm not really looking for lope, a slight lope is OK- and retaining vacuum..........
#37
I used there Comp 918 Springs, max lift is .600 and the cam is a .604/.610 so I was told they would work fine, and they have been perfectly fine but next time around I would go with what they recommend or a nice dual spring like you said.
#40
sup
Ok im running what they call a GM hotcam. Its a 218/228 .525/.525 on 112. I have 3.42s out back and stock converter. I wanted a good thump at idel and got it. It has awsome mid range power now too. My springs are the yellow zo6 springs and comp pushrods. But my truck has some miles on it and that cam didnt help my lifters any. They are starting so have some sound at high rpm so just keep that in mind bro.
