Good cam to run NA before turbo biuld
I want to get my truck paid off before I turbo it. So is there a good cam to run with a stock stall for my 6.2 for about 1 to 2 years. That will still have some gain over the stock cam and still be friendly when the time comes for the turbo. And since I am going turbo should I keep the VVT of go with a non VVT cam. If I delete the VVT all in need is a LS3 gear and timing cover right?
I was looking at a tripple 12 or BTR stage II but I'm not sure how they would work with a 6.2
My truck is a 2008 6.2 denali
I can't find much info on that cam in a 6.2 most of them are in 5.3's. Wouldn't it be a-little small in a 6.2. I don't know I'm just asking?
What is JFR short for?
Thanks George I was hoping you would respond to this. My goal with this truck is to mimic your lifted crew cab. A turbo 6.2 that can still tow my wakeboat on the weekends but still dip into the mid 12's. I just can't do it all at once so I would like to knock out the cam at the end of the summer. Then turbo after it's paid off the following year.
After doing alittle searching I'm guessing the cams stock48 sells????
