a good supercharger cam for a 4.8?
im planning to pick up a magnacharger to slap on my 4.8 and id like to add a cam that would work well with the setup....what would be some suggestions? would it require extra tuning?
LPE's GT2-3 seems to be a all around good FI cam.
I think it would do well in a 4.8L, and it has good idle/drivability characteristics.
I dont think it would absolutely require tuning, but it would definitely help.
Originally Posted by anarchyracing
okay is the Lingenfelter Performance GT2-3 cam actually a roller cam? what else would need to be replaced to make that cam work with my 4.8?
Check out my sig. It may give you some ideas. My cam requires a custom tune. Mine is a nice cam for the little 4.8 and an everyday driver if it is tuned right. The GT2-3 is probably a little less hassle to tune and deal with due to the wide lobe sep. It maintains a mostly stock idle from what I understand. Also I lost 3lbs of boost with my cam and headers combined and went to a smaller pulley to get it back. I haven't had mine dynoed since I've had more tuning but I'm expecting in the neighborhood of 475rwhp 500tq.
im not knocking this cam at all..it's a good cam but LPE's GT2-3 cam was designed for the vette with a radix that turns upwards of 7000 rpm...i dont plan on spinning my motor that fast so im going with a 220/224 – 580/581 – 115 .... this custom grind should give me everything i want under 6200 rpm's...we will see soon!!! i think the install is the 16th.
Originally Posted by moregrip
say what? 220/224 581/581 115, comp cams XER?
power should come in around 2000 rpm's ..should be a good mid and upper cam....
