Guide my Cam please!
Between the 2, if the price was a steal, I'd pick the Vinci...but that definitely is a baby cam, even compared to mine (206/212 .515/.520 114). Great daily driver with a nice improvement over stock, but you can still go bigger and maintain daily driveability and get away with a stock stall tq converter. (although even a stock truck would benefit from a good verter IMO...something in the 2400-2600 range would probably be perfect for my cam)
My truck idles and has a powerband that is similar to stock, just stronger...it got me .9 tenths and 8 mph in the 1/4 mile...running on 33" BFG AT's. (almost forgot to add...a PCMforLess 02 PCM also, which I'm sure had ALOT to do with the improvement)
if you want stock idle, then that baby cam would be fine.. even the 206/212 should idle like stock..
either way, nelson does 3 free retunes per year so why not just get a bigger cam and get him to re idle it for ya?
Its not that hard to swap PCM's
if you do the cam swap yourself, then that 200/208 might be fine... but paying someone for those slight gains wouldnt be worth it?
any cam in the 206-212 range should give ya 3tenths atleast in the 1/4th roughly... figure 30hp gains from them
BigEd_72455
08-08-2015 04:49 PM
cams 98 silverado
07-31-2015 07:36 AM
