Guys with 243's
Old 02-11-2009, 06:35 PM
rst06rado's Avatar
Default Guys with 243's
I just picked up a set of untouched LS6 heads and was wondering who was running them on there trucks, and if they had them milled at all? Thanks.
Old 02-11-2009, 06:55 PM
Truckshop's Avatar
you have to mill them to keep compression at stock levels. they are a good upgrade for what they cost. i would send them to someone to have them ported to really get some bang for your buck.
Old 02-11-2009, 07:10 PM
dirt track racer 81's Avatar
i have a set on my 370. i milled them .030 for a cr around 11.4:1
Old 02-12-2009, 09:43 AM
rst06rado's Avatar
Thanks Truckshop and Dirt Track Racer 81. Anyone else?
Old 02-12-2009, 09:52 AM
nighthawk08's Avatar
what engine are you putting them on?
Old 02-12-2009, 11:31 AM
rst06rado's Avatar
5.3 with the gm hot cam.
Old 02-12-2009, 11:38 AM
Wearin' da big hat
00ChevyScott's Avatar
I'd say to use 5.3 heads and get them worked over so you can run a higher compression.
Old 02-12-2009, 12:20 PM
rst06rado's Avatar
Well what I had in mind was to use these LS6 heads. (which I imagine flow better than my stock?) Then have the milled to bump my compression. Am I going in the wrong direction? Anybody running 243's on there 5.3?
Old 02-12-2009, 12:27 PM
you have to mill quite a bit to actually bump your compression on a 5.3. you actually have to mill them just to get to stock compression. they're good heads for a 6.0 though.
RandomHero's Avatar
I remember sport side swapped to some milled 243s with his 5.3L and 220 split duration cam and didn't gain hardly anything.
Quick Reply: Guys with 243's
