Harmonic Balancer broke and Damaged the Crank
#21
So just an update for everyone I pressed on another balancer and got a new bolt from my local dealership. I used medium Loctite and my buddy's impact to torque it down. Well I was driving to work the other day and the bolt somehow backed out again and the new balancer broke off the crank again. Im not sure what to do now should I try to press a third balancer on there or just pull the motor and replace the crankshaft.
I wound up getting a Kent-Moore Fly Wheel Holder tool to torque it to spec but I think the damage was already done. A couple of years later I spun the front main bearing.
I purchased my truck new and had it Supercharged with a kit the dealership installed so that it would be covered under the factory warranty. The truck was in for service and while they had it the balancer rolled off on them and they replaced the crank automatically.
Not to sound insensitive to your situation but based on my experience the pin has been pulled on the grenade...twice.
#22
#23
I’m not saying that it’s the best possible solution, but if your crank snout is a little wore down so that the balancer is no longer a somewhat press-fit after all these events and you can get a new balancer installed and the threads are in good enough condition to properly torque down, I would suggest to also install a pinning kit like you would normally do for a supercharged application. By doing so, it will keep the balancer and bolt from trying to spin and back off.
#24
Great of all the years and motors I've touched with buddy's- reused some, replaced some depending on there funds-
Hope mine doesn't come loose with the magnacharger, I have yet to pin the crank.....
#26
Thanks for all the replys guys that s kinda the route i was thinking to press a third one on a pin it before i decide to pull the motor. And the impact i used was at my buddies tire shop its pretty strong not sure how much torque it can put out though. Do you guys recommend the pin kit that pins from the side or the one that pins from the front washer.
#27
This exact same thing happened to my buddy a couple weeks ago also. He has a tbss. Crank bolt came out and lost the balancer. When he was reinstalling the balancer. It was loose on the crank. He ended up keying it. Someone makes a key kit so you dont have to pull the engine. Its a 2 piece balancer.
#28
Wrecker 426
09-30-2015 10:39 PM
