head choice and opinions needed.
I have a Lq4/th400 stalled that I originally set up for boost.
it has ARP studs, rod bolts ect. Medium cam, turbo gapped rings, UD pulley ect.
Right now I have ported, polished 317 heads with chamber work, and milled .010.
I cant go turbo for a while, And I have a set of 706 truck heads also. But they are stock. Which ones should I run for best performance? I will be running stock manifolds, and have it SD tuned. 3.42 gears on a 30'' tire. In a 4k# truck.
I know My ported heads flow way way better, but would the small combustion chamber yield better performance?
Ran out of money. And need the motor in, as the v6/tranny is going out. I thought about it, but when I do get money for turbo, Ill put the 317's on (If I choose to run the 706)
You think? The 317's are already on and torqued down. But If the 706 will make better power ect... I will run them. You think the good flow and Lower compression will make more power than High compression and lower flow?
I dont have a clue.
Keep the 2 cents coming guys.
