Head confusion causing a Head ache!
Old 07-28-2011, 02:53 PM
TORQUE RACING's Avatar
Default Head confusion causing a Head ache!
I have a 2002 silverado ecsb 4x4. Dropped 2" rear with 30"tires. I am looking for the best set of heads for this truck. I am running a custom grind bullet cam 226/232 @ 0.050 with .610/.610 lift 110+4 LSA, 95mm typhoon intake long tubes, no muffler. Which heads has best flow numbers and work best. I dont care about ported flow numbers i want stock numbers. Potential head numbers: 243, 799, 317, 821, 241, 8452. Any comments on these heads?
Old 07-28-2011, 03:03 PM
Chevy_King1500's Avatar
https://www.performancetrucks.net/fo...-5-3-a-482490/ about 10 questions down
Old 07-28-2011, 03:07 PM
Question
which cam are you really running, because you stated you got a different cam in your other thread and 799 heads.
Old 07-28-2011, 03:14 PM
well to be honest with you i have both 223/230 .601/.601 110+4 LSA and 226/232 .610/.610 110+4 LSA which ever one i do not run i am selling to a friend. I got way out bid on the 799 heads so i spoke too soon so now im trying to find out which heads are best
Old 07-28-2011, 03:51 PM
blackcash's Avatar
milled 243/799's
Old 07-28-2011, 03:54 PM
i was looking to do 243/799 milled to a 59cc and port work with acid etched intake ports. So has everyone had good luck with the 243/799s?
Old 07-28-2011, 04:04 PM
Praise The Lowered
RibeiroBJJ's Avatar
Since you asked what the "best" heads for a 5.3 are..I would say a set of the 205cc genx TrickFlows would be the "best" heads for your setup (If you plan on staying 5.3) They would work well with the larger lift Bullet cam you have...You are definately going to need a higher stall converter..
And tied for 2nd place would be the tea or prc 5.3 cnc heads..maybe take a look at the sdpc ones as well ?? all imho of course
Old 07-28-2011, 04:13 PM
13 Second Truck Club
grey matter 04's Avatar
the best stock head would be a 243
only down fall is a 64.45cc combustion chamber,must be milled if used on a 99-06 5.3
A ported head or aftermarket head is a whole new ball game
Old 07-28-2011, 04:19 PM
Are the trick flows better that P&P 243s?
Old 07-28-2011, 04:21 PM
and i have a 3500 stall forgot to mention
Quick Reply: Head confusion causing a Head ache!
