Head gasket opionions?
Old 01-27-2006, 09:12 PM
Question Head gasket opionions?
Got a 5.7 LS1. I need to get some head gaskets and wanna know if I should go with some stock 5.7 ones or some Fel-Pro or other aftermarkets? My compression is probably a bit over 11 with my shaved 5.3 heads on the 5.7. I'm not really sure how to calculate it.
Old 01-27-2006, 10:24 PM
1Bad454's Avatar
Their are compression calculators available on line. I have Cometic head gaskets but thats because I'll be supercharging my motor pretty soon.
Old 01-27-2006, 10:32 PM
9 Second Club
Rhino79's Avatar
I'd go with Cometic as well.
Old 01-27-2006, 10:41 PM
99Silver6.0's Avatar
Cometics. They are kinda finnickey to TQ'ing. SCE makes a good gasket too.
Old 01-29-2006, 06:00 PM
11 Second Truck Club
L-EATER's Avatar
There is no reason to use anything other than the stock MLS gaskets. They are cheap, proven, and tough. Do a search on LS1 tech and see how many people have had issues with the Cometics........
Old 01-29-2006, 11:38 PM
1Bad454's Avatar
Cometic gaskets require a fresh mounting surface from what I recall. My engine builder said all the racers loved them (now this was 6 months ago).
Old 01-30-2006, 05:27 AM
tdrumm's Avatar
I'll be using Cometics when I do my swap too. I bought them instead of stockers because they were available in thinner thicknesses.
Old 01-30-2006, 07:39 AM
TurboGibbs's Avatar
I'd use the factory multi layered steel. They are one of the parts that were developed through racing and applied to factory engines. The Cometics and factory MLS are the same basic design and the GM's are a lot cheaper.
Old 01-30-2006, 07:56 AM
9 Second Club
Rhino79's Avatar
What is the bore size(s) on the stock gaskets?
Old 01-30-2006, 09:22 AM
TURBHOE's Avatar
what is the part number on these stock gaskets i need them for my ls1 when i tear it down for rebuild.
Quick Reply: Head gasket opionions?
