Head Gasket Problems..
Old 05-04-2008, 11:20 PM
hirdlej's Avatar
Stock specs? the torque to yield procedure? you know with arp bolts that if you use the stock head bolt procedure you end up torquing the heads down to around 150 ft lbs right?
hirdlej's Avatar
let me find you the link, brb in a few
Old 05-04-2008, 11:26 PM
hirdlej's Avatar
If you did the factory torque sequence on your ARP bolts you more than likely had them torqued to somewhere aroung 150 ft lbs
https://ls1tech.com/forums/showthrea...lts+arp&page=2
Old 05-04-2008, 11:30 PM
dirt track racer 81's Avatar
i take that back not stock specs but the specs for arp bolts..im tired and not all here right now
Old 05-04-2008, 11:35 PM
haha thats funny..i torqued mine to arp stocks..just wasnt thinkin at the time i said that
Old 05-08-2008, 09:50 PM
oldred95's Avatar
Thats interesting. Are those multi layered steel gaskets or just a single thin stamped steel piece? I used felpro steel shim gaskets when I went with vortec heads and I like them a lot. I was skeptical but they worked out good. They have some type of sticky coating on them thats sort of like high tack I guess.
Maybe you should slide a Gen I block in there with 5 bolts per cylinder. I'll probably get shot for saying that on here.
Old 05-08-2008, 09:55 PM
i gotta 13:1 355 in my dirt track car ive thought about puttin it there but honestly i like the ls1 engines alot better..
Old 05-09-2008, 02:02 AM
TurboGibbs's Avatar
I've seen the gaskets look like that on boosted engines with factory installed heads and bolts, arp bolts, and arp studs. Never had any issues with the MLS gaskets, just signs of blow-by as in the picture.
Here are some of mine from a while back.
Old 05-09-2008, 02:15 AM
How do I change this text
Wilde Racing's Avatar
Originally Posted by dirt track racer 81
i used arp rod bolts
Should have went with TTY
LMAO
Sucks to see them leaking with such little drive time.. I would think it would stat pushing coolent first though.....
Old 05-09-2008, 02:26 AM
nonnieselman's Avatar
LMAO
Are the stockers better than ARPs?
Quick Reply: Head Gasket Problems..
