Head milling for Cleanup only
Old 06-12-2010, 02:08 PM
TrickyTransAm's Avatar
Default Head milling for Cleanup only
Have you had your heads milled slightly for cleanup?
What did you do about valvetrain clearances? Did you have to special order shorter push rods, or did you install shims under the rocker arm bolts?
Old 06-12-2010, 02:20 PM
PT's Slowest Truck
budhayes3's Avatar
After milling the heads you'll need a pushrod length checker (less than $20), then you can order the correct length pushrods, Comp makes multiple sizes that work on the GENIII engines.
Old 06-13-2010, 01:19 AM
8 Second Truck Club
Blown06's Avatar
Milling the heads just enough to clean them up should not affect your valve train geometry enough to need new pushrods. Unless it's taking a ton to clean them up. I milled a set of 243's with 100000 miles on them about 2 months ago and it only took .008 to get them back flat. Threw the motor back together with the stock pushrods and car runs perfect.
Old 06-13-2010, 01:23 AM
Baltimore Whore
Mangled03gmc's Avatar
Agreed.. That should only take a few thou off to clean them up unless they are beat. The lifter should be able to take that little bit up.
Old 06-13-2010, 08:00 AM
PT's Slowest Truck
budhayes3's Avatar
Well I suppose at a few thou there shouldn't be any major issues, but personally, I'd still check lifter preload, for the cheap price of a pr length checker and the little bit of time that it takes to check, why not? Just for reference, stock length pr is 7.38, and aftermarket pr's are offered in increments of .025 (ex: 7.4, 7.375, 7.425, etc.)
Old 06-13-2010, 05:17 PM
GFYS and STFU
Spoolin's Avatar
I would assume if someone's running solid lifters than it would be more of a concern than someone running hydraulic lifters right?
Old 06-13-2010, 09:28 PM
PT's Slowest Truck
budhayes3's Avatar
Absolutely, the plunger in the hydraulic lifter will allow for some play with the valvetrain geometry...I can't remember the exact number, but there is a certain amount of allowable clearance that the hydraulic lifter will account for.
Old 06-13-2010, 09:45 PM
Baltimore Whore
WTH kinda NEWB ???? is that Julie ??
Old 06-13-2010, 10:27 PM
11 Second Truck Club
MPFD's Avatar
My question is do you play "on a boat" for all those honeys you got pictures of on the boat?
http://www.youtube.com/watch?v=k8F3UE9qFsg
Old 06-13-2010, 10:32 PM
Baltimore Whore
Funny thing is your damn rite we do.. Gets the girls freaky..
Quick Reply: Head milling for Cleanup only
