Head water temp hole plug size?
I dont know but i will tell you its not NPT, ive tried!! If you have your water temp sensor take it out and go up to home depot or lowes and put it in the thread checker on the hardware isle if that helps ya out any
It's metric, like 14 x 1.5 or some where around there. It's very close to 3/8npt I believe and you can run a NPT tap down it and re-cut the threads. I did that on my dads truck for the mech water temp gauge and it worked fine.
FlowmasterMufflers
07-30-2015 05:03 PM
