Which heads on a 4.8l Turbo motor? 243 or 317 heads?
Old 12-09-2011, 11:23 AM
NemeSS's Avatar
243s unless plan on 30psig, then go with the 317s.
Don't mill if don't have to.
If have to, keep under .010.
.005 if possible
Old 12-09-2011, 11:42 AM
pewterliftedz's Avatar
Run a set of ported 862s. a 4.8 is going to be a dog out of boost with low compression. You can safely run 15 psi on 9.8:1 compression, its all in the tune. Do not mill a head for boost applications.
Old 12-09-2011, 11:53 AM
Custm2500's Rude Friend
1FastBrick's Avatar
X2 !!!
Personally I wouldn't try to push it past 15 although guys have reported runing as much as 19 PSI with a conservative Tune...
Old 12-09-2011, 12:36 PM
03regcab sierra's Avatar
So why not mill the heads? It it because of higher compression or because the heads have a weak point?
Old 12-09-2011, 03:51 PM
1FastBrick's Avatar
Because you weaken the deck and lose clamping force. This would make it more likely to lift a head gasket under boost conditions.
Old 12-10-2011, 10:34 AM
1989k1500's Avatar
24 on an LQ9 in my friends car. And another friend of mine ran 19 in an L33.
Old 12-28-2011, 09:35 PM
La_BigShit0389's Avatar
ill go for 317 heads for low compression for boost
OHsixLS3
12-27-2016 09:30 AM
chopperloco
07-10-2016 10:45 PM
GrooveCityZ71
08-31-2015 12:05 PM
jmarkway
07-18-2015 09:23 PM
06 4.8
07-15-2015 07:17 PM
Quick Reply: Which heads on a 4.8l Turbo motor? 243 or 317 heads?
