Heads and cam install now truck wont idle???
Hey guys im having a problem with the new 6.0l with texas speed ls6 heads and tsp 233/239 cam that I swapped into my truck.I cant seem to get the truck to idle unless you keep ur foot on the gas and it wont rev past about 3800.I double checked all the grounds they seem to be hooked up.The pcm was tuned by texas speed.Im guessing it has something to do with the 5.3 to 6.0 swap I used my 5.3 intake...Im stumped any help would be great Thanks
I did get the truck to idle last night after pedelin it for a bit....once it did idle the afr looked good 14.7-15.0 but wouldnt really rev past about 3500 and was hesitant to 3500. maybe a ground issue??
