which heads? L92s or stage 2 243s???
#23
some of the posts
Looking forward to results of ur build. I know u got ur setup figured out already. But as tsp suggested. There cathedral ports heads would work excellent. I'm a trex man so I would take that over the ms line. But more than likely ur gonna have to cut in vr and check final ptv clearance before buy pushrods and button it down. Gonna have to actually verify how much the piston is out the bore TDC. To figure final scr and quench. I recommend the ls2 head gaskets . Not the stock lq4 or 9 gaskets
#25
I think I am leaning more and more toward the l92 heads. Check clearance and get them ported. Great flowing heads and big enough if you ever bore or stroke it you already have some heads. May have to get them reworked but you still have them. I just dont see the cathedral port heads coming close to the potential the L92 heads have. my .$02
#26
all in all if the heads fall into the right porter you'll be surprised at the performance gains from either head !
#28
my honest opinion, though i made good use with the l92 heads on my 4" bore lq9 364 stock 6.0 i still wasnt getting the full affect of the heads, if i would have stayed with the orginal game plan and ran the stock shortblock with more nitrous it would have prevailed to be used ( heads ) to there full potiental, well almost. right now i have a 410 CI motor being built by rage, which is nitrous fed, which will hold plenty, this isnt gonna be your normal street friendly truck, yeah you can NOW concider it a race truck hahahaha, but still beable to drive around the block or so as for cubic inch i think these heads would luv a bigger CI motor above the 410 anyway, how big depends on how well the heads are worked. i run the standard valve size : 2.165"/1.59" Valves BUT with the hollow stem intake valves, i like rpms so its a must to keep the valvetrain as light as possible this motor is being built with the best parts available !
#29
Tin Foil Hat Wearin' Fool
As time goes by I think Im becoming more and more of a fan of the L92 heads. Only problem with them is FAST doesnt make the lsxrt manifold in square port only cathedral at the moment. BUT a ported L92 truck intake was proven to flow damn good which should be plenty enough to get you into the 11s no problem. I bet you could have an 11.50 truck in good weather pretty easy.
If I were you my setup would be
LQ9
WCCH Stage II L92s
232/238 112 ordered from TSP
LS2 portworks ported L92 truck manifold
TSP 1 7/8 fbody headers
Dual 3" with an x pipe
3600 Circle D single disk or tripple if you got the cash
410s with trutrac
all the other usual boltons
That should get you to where you want very easily but more like mid 11s in good weather
LQ9
WCCH Stage II L92s
410s with trutrac
#30
LQ9
WCCH Stage II L92s
410s with trutrac
LQ9
WCCH Stage II L92s
410s with trutrac
the list you posted would get him there, but to be all out would take more, gears, bigger stall, even with the truck intake being ported, if it can hold its torque around 3k-3500 then open it up on the top end would be WOW! then by all means that 3600 or 4k ( gotta have a triple disc ) will work badass.
the LAST pm i got from D_K was he wanted a BEAST, A MONSTER, if this is the case screw the 4:10 gears, go bigger, i would rest on some 4:56s and nothing less than a nice triple disc stall, talk with the guys im sure cirlce d, yank, precission industries, could offer some damn good advice, myself would mention a 4c stall from chris, specially if you decide to spray any amount of nitrous, i felt i lost alot when i was spraying concidering i was built for NA horsepower on the 4400 with a 5c stall, chris mentioned i probably would or more then likely loose 20-30% through the converter, personally i think he was correct..
by the way, i still have that shortblock and its being studded i offered it to one person if he wants it its his if not it'll be oiled then put on a shelf for a rainy day!!
