heads milled .045
Old 12-17-2010, 11:36 AM
Bumpers's Avatar
Default heads milled .045
I have a set of 243s milled .045 and the machine chop checked them with plexiglass and a dripper and said they were 59cc chambers.. Anyways I'm wondering if I'm gunna have any issues as far as ptv clearance or anything of that nature.. I have stock mls gaskets I will be using. My luck I will have to shim the intake or somthing too but I'm wondering if I'm gunna have mechanical issues??
Thanx,
Garrett
Old 12-17-2010, 02:21 PM
Formerly darynC-10/23/10
Daryn's Avatar
them heads are junk ... junk junk junk.... since im in a good moood today... i guess ill take that junk off your hands
Old 12-17-2010, 02:31 PM
mhotrodscooter's Avatar
The ones I got or supposedly milled too .042 & or 58cc. I didn't have them checked though, but I had no clearance problems with stock gaskets.
Old 12-17-2010, 03:17 PM
hirdlej's Avatar
If they milled them on the intake side of the head as well, you won't have any sealing problems.
Old 12-17-2010, 04:36 PM
Bumpers's Avatar
They are stock lq4 pistons.. Cam is a 226/230 .598 .600
Old 12-17-2010, 04:57 PM
Bumpers's Avatar
exactly what i wanted to hear
yes they milled them on the intake side too
Old 12-17-2010, 05:20 PM
Bumpers's Avatar
pat g says 10.8 ? i was thinking it would be a hair over 11
Old 02-03-2011, 10:36 PM
Bumpers's Avatar
Just to let you guys know if someone stumbles across this thread in the future looking for info .. It worked like a champ. Everything lined right up just fine and it started and didn't break a valve so I'm guessing the ptv clearance was good lol
Old 02-03-2011, 10:51 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Go out and tag the rev limiter a couple of times real hard, that is the true test.
Old 02-03-2011, 11:02 PM
dmelvin's Avatar
I've got a set of 243's that are milled .03 and was told that they were 59cc cambers...
Looking around I saw somewhere that .006=1cc?
I guess I'm confused as to how your's being milled down .045 would bring you to 59 and not somewhere around 56.5?
Can someone please school me?
Quick Reply: heads milled .045
