Heads N cam
Old 12-12-2009, 01:16 PM
luis06's Avatar
Default Heads N cam
Ok i'm finally goin to do heads n cam. the heads are patriot heads not sure which ones chamber size? what cc it flows my buddy is giving them to me in exchange for swapin motors in his car. theres no part# that i can use i know there a 243 heads but thats it. my concern is the cam im goin with comp cams xr265hr
212 int./218 exh 0.558 int./0.563 exh. lift
the spring on the heads are double spring .650 max lift is this too much over kill. also injector if i put 8.1l injectors well that be fine for now or are the stock ones ok and fuel pump do i need to upgrade. help anyboby my truck has 104k what else should i replace
Old 12-12-2009, 01:33 PM
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
id do a ls2 timing chain since your over 100,000 IMO
Old 12-12-2009, 01:36 PM
charcoal03silvy's Avatar
Agreed, the stocker could be stretched out.
Where abour in OKC are you?
Old 12-12-2009, 05:30 PM
luis06's Avatar
I stay over by I-240 behind the homedepot on shields wat bout u. the chain is on my list wat bout injectors and fuel pump im also gettin an undrive pulley and alt pulley
Old 12-12-2009, 08:08 PM
PT's Slowest Truck
budhayes3's Avatar
Great cam...I don't think that you need all of that spring stressing out your valvetrain though. You could sell those springs in the classifieds here and get yourself a new set of PAC 1218's and be good to go. Spend $18 for a Comp pushrod length checker and buy some hardened pushrods for your setup. Are the heads milled? If so, you'll be needing shorter pushrods.
With the heads and cam, your injectors may end up maxed out or very close. Some 30# gas 8.1 injectors should be enough, or you can go with the marine 8.1 injectors and have plenty extra if you ever mod further. Your stock fuel pump will be fine, and I'd use factory multi-layer steel head gaskets. You'll need either new factory head bolts, as they're torque to yield and can only be used once, or some ARP head studs or bolts. From what I've read, you can't get the heads on the engine while it's in the truck if using the studs...you'd have to install most of the studs (except some of the rear ones), drop the heads on, then install the rest of the studs with the heads in place.
Since the heads will already be off and you'll be putting a new bumpstick in there, now would be the time to replace the lifters. IIRC, a set of LS7 lifters is less than, or right around $120 from SDPC (sponsor, link to right). Both SDPC sell head and cam install kits that include all of the gaskets, and can be pieced together with either factory bolts, or I believe the ARP goods that I already referred to.
Sounds like a nice set up that you're going to have...we all know that the Comp 212/218 is a proven performer. What LSA is that cam on, is it the 114 or 115?
Old 12-12-2009, 08:22 PM
Off of SW 134th between I-35 and I-44
Old 12-12-2009, 09:59 PM
luis06's Avatar
cool thanks for the info. i'm gettin those lifters w the heads is it ok to use them. not sure how many miles on them. Oh the cam is the high lift one im gettin it on a 114 lsa. We should race one day
Old 12-12-2009, 10:02 PM
Hah my truck is bone stock except for a CIA and muffler But it's getting there!
Why a 114lsa?
Old 12-12-2009, 10:11 PM
luis06's Avatar
i want to sound a little choppy i guess thats it
Old 12-12-2009, 10:17 PM
dirt track racer 81's Avatar
who you gonna have tune it?
Quick Reply: Heads N cam
