View Poll Results: What cam does my 4.8 need
220/220 .581/.581
13
59.09%
220/220 .564/.564
40.91%
Voters: 22. You may not vote on this poll
Help decide between these two cams
This is for a daily driver 4.8. Right now Im going to use a Trailblazer torque converter, but plan to step up to a 3000-3200 Circle-D in the new future.
I was planning on using a set of Comp 918 springs I had, so I was set on the .581 lift, but got to doing some research and wondering if I may be just as good going with the lower lift and some LS6 springs.
Also help me decide on my LSA
Cam 1. 220/220 .581/.581 Comp XER lobes
Cam 2. 220/220 .564/.564 Comp XE lobes
I thought I wanted a 112 LSA + 4, but now Im thinking I may want a 110 +2 or +4
Help me decide.
Help me decide.
PT's Slowest Truck
Depends on the heads IMO, lower lift for stockers, higher lift for worked heads...I'd run PAC 1218's for either considering how high you're going to have to spin it in a 4.8. I like the 112+4 also because I'm a little more LS traditional lol, but a lot of guys have been running tighter LSA's lately with good results...^^^
It's gonna be the factory bone stock heads.
Bud, it's a temporary engine. I'm either gonna reuse my old comp 918s or new LS6. As crazy as it sounds I'm trying to half *** do it on a budget
Personally, id go with the .564" on a 112+4. Lift will suit your stock heads, the 112 lsa will give you a flatter curve than the 110, and the +4 will bring the power in sooner. I think that cam will be a monster in that motor. I will be swapping my cam in the future to something like that, just a bit bigger to suit my mods.
