Help me with my 370 build.
#33
Update. Motor will be done on monday. The clevite main bearing didnt come in on time so... But on a side note got the new cam ordered. Comp Cams
224/230 581/588 114lsaXER. Do you guys think 918s will be ok for this cam. I know the max lift is 600. Now all i have to do is get my 243 heads ordered from patriot and get a set of head studs. Does anyone know what head studs i need. There are so many different part numbers for them.
#34
FormerVendor
The head studs you need depend on what year your block is.
#37
Okay. But looking at the bolts all of the bolts that in the center of the heads are the same. The bolts that are buy the exhaust side of the heads are shorter. What about the bolts by the intake on the heads?
