Help picking cam for 5.3 s10
Im in the process of installing a FLT lvl4 trans with a Yank ss3600 into my 5.3 s10. I was thinking it would be the right time to install my cam as well. The truck is a reg. cab weighing about 3500lbs with me in it. The setup includes:
>Ls6 intake manifold, CAI, ported TB
>Sanderson shorties, X-pipe, dualindualout muffler(no cats)
>3.42 gears, A.R. Irocs 18"x8", Nitto555(275/40/18)(rear),
>50,75 or 100 dry shot
I was looking into the TR-220/220 112 because of the great numbers and ETs that 5.3s are putting out with this cam, but Im now looking into a custom grind to make sure it will match my setup and make the most power without going over board for a daily diver.
Any advice would be appreciated.
Head work depends on where you go...it could be a couple hundred from someone local, to almost 2 grand for a nice cnc'd set of heads. I like WCCH (sponsor, link to right>>>). I have a set of their StageII 317's that will be going on my LQ9 when I build it. They have some offerings for 5.3's also, including the new Edelbrock's that I believe they have worked.
For your daily driver I'd look for something on a 112-114 LSA. The TR224 is a proven performer in the 6.0's, and some have run it in their 5.3's. You could also do a Comp 222/224 .56x/.56x 112...(can't remember the lift but it's on Comp's website) the verter is a little more than that cam needs, but will still work well. Zippy (who is a member here and an Admin at SilveradoSS.com) is running that cam in his 5.3 and likes it a lot. Can't remember what converter he's running though...
