High Oil Press :( dont know what to do
Old 12-07-2010 | 11:18 PM
hyespeeder's Avatar
Default High Oil Press :( dont know what to do
Ok guys so finally i got a good motor....
I got a ls6 shortblock it was in good running condition....
I put in a new oil pump thats off the LSA motor Cts-v...
Car started up ran fine except my oil press is at 60 COLD and over 80 at WOT...
After a few runs the rear main was leaking baddd almost pissin
I had put in 10-40 wt oil just to flush the motor ... So i am like ok fine its the heavy oil ... dumped it and put 5-30 Edge ... Same problem....
As of now there are not oil coolers or anything...
Does anyone have a idea ... i am lost..... My next thing is putting in a oil cooler i got... but if that does not do it then idk..
I think the oil press has something to do with the rear main leak ?
Thanks guys
Old 12-08-2010 | 09:01 AM
Tootall's Avatar
did you put the oil pan on first, then the rear cover? . . . might be miss aligned.
Put a little RTV in the bottom corners of the cover too.
Old 12-08-2010 | 11:43 AM
double047's Avatar
14 Second Truck Club
Wow, I only wish to have good oil pressure, I'm with Tootall check out the alignments and fit then RTV it.
Old 12-08-2010 | 12:37 PM
hyespeeder's Avatar
Ya i did the alinement and rtv everything ... its leaking from the main seal....
I am gussing its from too much oil press ... what do you guys think ?
Old 12-08-2010 | 12:55 PM
my oil pressure at idle is 20
Old 12-08-2010 | 01:04 PM
Tootall's Avatar
wrong oil filter will do it too . . .
Old 12-09-2010 | 03:18 AM
hyespeeder's Avatar
I have a K &N in there ...
which one helps drop psi ?
LOL
Old 12-09-2010 | 03:38 AM
LS1TRUCKGUY's Avatar
my oil pressure is 60psi @ idle when cold.... 50psi warmed up and pegged out over 80psi at WOT... it has always been like this
Old 12-09-2010 | 11:22 AM
charcold-bowtie's Avatar
You could probably do something like this. Im not sure the oil pressure would cause a rear main leak, the oil in the pan isnt under any pressure I think
link
Old 12-09-2010 | 01:04 PM
TXsilverado's Avatar
your oil pressure sounds normal to me...
