Holley Hi-Ram intake for cathedral port?
Old 05-14-2012 | 06:12 PM
SweetS10V8's Avatar
Originally Posted by TimDave217
it just no real story's of people actually doing so.
Dont need storys, I lived on the dyno for the past 6 years. Its simply not suited for your combination.
If you want a story.... This is what yours will be, but worse. Because this was on a 6.0L....(ProFlow XT intake, but will be very similar.)
Originally Posted by Raffman
Well I just confirmed my thoughts with Richard @ WCCH , this intake gives up way too much bottom end for my application. I'm almost a second slower at the 1/8th mi strip and throttle responce is a little lazy.
Richard says they act a lot like the victor (3500-7000 rpm) but shorter runners, so it would have to be for a lighter vehicle, looser converter and lower gear or something that can afford to give up so much bottom.
I'm running a 4L80E, 3000 stall with 3.73's and don't want to change and give up driveability. The fact is there is nothing out there currently for most of our trucks. FAST is supposily working on a truck only intake but sure it will be big $ when and if.
So I'm going back to the LS6 intake, it falls off some at the top but I was in the high 7's at the 1/8th with it so not too bad.
My only regret.........I sold my LS6 intake.................................
Old 05-17-2012 | 05:00 PM
TimDave217's Avatar
thanks you for posting that, thats what i needed to see, and like i said i dont plan on ever using this intake for my little motor but i do like this intake and what there doing with it.
Old 05-22-2012 | 02:36 AM
s/c'd cav's Avatar
Originally Posted by SweetS10V8
The problem is the torque loss from it being a high rpm manifold. It might look cool, but its not a proper match for a big heavy truck with a little engine. Its design fall into this family of intakes(pic), Like said before (quote below)
funny thing is , your truck intakes are a LONG RUNNER DESIGN also
if you look at the ole TPI motors and LT1/4 , the TPI was a long runner and made more low end grunt , the LT1/4 made more high end power
Old 05-22-2012 | 03:06 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
The manifolds in question are not long runner... Stockers, yes. Holley High Ram, no, ones pictured above, no.
Old 06-29-2012 | 08:11 AM
slowec's Avatar
Holley News Hi–Ram Intake for Cathedral Port LS1 LS6 and Rectangle Port LS7 GM Engines
Old 06-29-2012 | 10:37 AM
Three6GMC's Avatar
You can order these from Jegs already for those who didn't know.
Old 05-13-2013 | 01:17 AM
TexasGMC08's Avatar
Wondering If anyone has Installed this Intake? If so was it worth it?
Old 05-13-2013 | 01:58 AM
Atomic's Avatar
I have a gauge for that
Really blowing up the holley hi ram threads tonight, eh?
Performance wise, the stock one is fine, unless you are reving 6200+, but it does look really cool.
Old 05-13-2013 | 07:12 AM
TexasGMC08's Avatar
lol yeah I was just wondering about it.... Then I found a thread that callies posted and I seen the power band @ 6300 was only 20hp more then with a LS3 intake and 90mm TB....So I got my answer with that thread.. not worth only if you want that look... You can send your intake to Russell performance and get it PNP and have better gains then that and less money.
Old 05-14-2013 | 07:59 PM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
Are you talking about sending in the truck 78mm? Or a tbss?
