how big of a difference
I'm planning my lq4 build for my 6.0/4l80 swap into my 4x4 tahoe. This is a DD so I'd like to see good fuel economy as well as performance, but no plans on taking it to the strip. Also it needs to be able to tow my boat and jeep.
After hours of searching here is what I am thinking: a nelson tune, CAI, pacesetter LT, cam, and heads
TR220 or TR224: I think the 220 will give me better economy but a lot of people switch to a 224. How big is the difference for my application?
As for the head Stock lq4 317 or Higher compression with the 862 w/ 6.0L valve. lower compression means I don't have to run 93 but higher compression means more efficent. how big of a difference will it make?
Thanks for the help.
FWIW you won't see what i'd consider to be good fuel economy with a 6.0... however, it should work nicely for towing. i'd get the TR220 personally, but it depends on what kind of stall you're willing to run.
I've been doing some more researching and Comp is recommending a 212/218 but i've notice alot people here run 220/220 or 224/224. what are the benifits equal valve duration vs have and exhaust valve open longer then the intake? alson what is the difference between 112 and 114 lsa
11 Second Truck Club
Before my gear swap (3.73 to 4.56) my 6.0 with a 225/229 cam made 20 mpg on interstate trips, but it was in a RCSB and it is 11-1 on a 91 tune....
My 5.3 best ever was 24 mpg, and the power difference was well worth the loss.
Apparently the 224 in the 6.0 will act more like the 220, just because of the displacement difference. There isn't all that much difference in horsepower between the two. Guessing 5hp.
Generally speaking - 112 will have more lope.
114 is more for driveability and will have a closer to stock idle, but you'll still hear it.
I was advised by one of the cam manufacturers to use the 224 in the 6.0 to go to the max performance, without having to run a converter, and other modifications, and to maintain decent driveability.
The 220 is supposed to be "THE" 5.3L cam.
