How do yall lock the motor to torque the balance bolt to 250 ft/lbs ?
11 Second Hall Moniter
You can make a flywheel hold tool with a piece of scrap strap steel 5 or 6 inches long. Drill a hole in each end. Bolt one side to the block or oil pan bellhousing bolt, and the other side to the flexplate torque converter bolt hole. Put a couple little bends on it so everything lines up.
thompson
33
03-01-2016 03:50 PM
redsilverado05
11-13-2015 05:34 PM
