How do yall lock the motor to torque the balance bolt to 250 ft/lbs ?
Old 11-13-2015, 07:46 AM
Vortec350ss's Avatar
I'll be honest... Mine isnt USA made and this is what I do.
Old 11-13-2015, 09:14 AM
11 Second Club
MrHorsepowerLSx's Avatar
Not recommended, but I have seen other "techs" before stick pry bars through the front of the hub and let the bar rest on oil pan bolts or in that general area then watch them crank down
Old 11-13-2015, 11:14 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
You can make a flywheel hold tool with a piece of scrap strap steel 5 or 6 inches long. Drill a hole in each end. Bolt one side to the block or oil pan bellhousing bolt, and the other side to the flexplate torque converter bolt hole. Put a couple little bends on it so everything lines up.
Old 11-13-2015, 02:10 PM
dirt track racer 81's Avatar
Pull the balancer on with my tool and hit it with an impact.
Old 11-13-2015, 02:14 PM
GMCtrk's Avatar
My IR cordless impact will do 700 lb/ft forward and 1100 lb/ft nutbusting.
Also, I always tighteb my balancers to spec with a long breaker bar and hold the balancer in place with the belt wrap method
Old 11-14-2015, 12:14 PM
blackcash's Avatar
Put my truck in gear (5speed) and a quick little blip with my 3/4" drive Matco. Problem solved.
HectorM52
06-23-2016 08:36 PM
thompson
33
03-01-2016 03:50 PM
YAMAHAGUY
54
11-21-2015 05:44 PM
redsilverado05
11-13-2015 05:34 PM
rob.los83
10-25-2015 04:06 PM
Quick Reply: How do yall lock the motor to torque the balance bolt to 250 ft/lbs ?
