How do you know if a crank needs to be turned?
High on diesel fumes
I am selling my crank and have had a few people ask if it needs to be turned. I don't really know what that means or how I can tell if it needs it. Can someone explain?
Any evidence of wear-scratches etc on the crank or rod journals. Turning is milling these surfaces down, smaller journal diameter, to a correct clearance with bearings for proper oil pressure. Basically a good smooth surface for the bearing surface. You turn the crank down then put larger/thicker bearings in.
Hope that makes sense
What Ky and bluecajun said + using micrometers to actually mic the diameter and compare with factory specs and tolerance. Basically on most late models if it is a smooth surface without scratches that you can really catch a finger nail on you are most likely ok.
legerwn
56
11-15-2015 11:21 PM
drummer0415
11
10-24-2015 09:16 PM
FormulaZR
09-14-2015 06:23 PM
