how high can a L92 spin
#22
i run the same springs, i have shifted at 7500, steady shift points at 7200 on a stock short block 6.0 go by your dyno sheet, theres no need to shift any higher since theres no hp beyond your peak power .. basically i didnt see any difference from shifting from 7k or 73-75 k
#29
I wouldnt spin past 6800 with the stock rod bolts. Iv spun a rod and a main in to different builds using factory rod bolts. safe to say i'v learned my lesson. The valvetrain is deffinetly good for it though.
