How much can you safely mill 799/243 heads?
should be around 9.9:1 with the stock gasket (.051") on a 05 lm7 with the dished pistons. with the flattop pistons that should be in your truck you should already be at around a 10:1 ratio.
if you milled to a chamber of 61cc (~.020-.024") you would bump up to 10.5:1
stayed stock and got thinner .040" gasket and a .010" cleanup mill would net you 10.5:1 and have a better quench.
Not to highjack, but Im wondering the same thing about my compression ratio. I have an ly6 with the dished/valve relief pistons and 799s milled .020. Ls9 gaskets .051 i believe. Where would this put me at? 10.2?
Good info here. So at what point did you guys decide on getting them milled? Sounds like you have aftermarket pistons. I have stock rotating assembly and about to tare mine apart for a mild build/update. Is it worth having the shop mill them down a bit or stick with the " just touch them to ensure they are flat " approach?
