How to tell
Old 06-06-2006 | 12:57 PM
spitfire2332's Avatar
Originally Posted by Colby 04
will this affect the way the transmission bolts up?
I've got an LQ4 and will be bolting up a 4L60E to it(I know, I know, it will fail)...but is there anything I need to change up for that? Everything should bolt up, right?
as long as its newer than 2001 (i think it was 01 and newer) you'll be fine. I cant member what all needs to be changed. But if its older than 01 you're fucked.
Old 06-06-2006 | 01:11 PM
thunder550's Avatar
High on diesel fumes
I couldn't tell by looking in the spark plug hole. I was pulling the pan to do rod bolts anyway, and looked at the connecting rods. The LQ9 has beefier rods.
Old 06-06-2006 | 05:43 PM
Quik's Avatar
5 year bitches!
if its a lq4 you will need your current flexplate to mount it to the 60/65 converter
Old 06-06-2006 | 06:48 PM
Colby 04's Avatar
thanks!
I would have dropped that thing in with the wrong flexplate
I assume by "flexplate" you mean "flywheel"...at least that's what I grew up calling it.
Old 06-06-2006 | 06:52 PM
thunder550's Avatar
thanks!
Flywheel is for a manual, flexplate is for an auto.
Old 06-06-2006 | 07:05 PM
Colby 04's Avatar
sorry, it's a bad habbit of mine. Either way, I now know that I need to change out that round toothed device strapped to the back of the block
Old 06-06-2006 | 07:12 PM
thunder550's Avatar
