how will this cam run
I have a ly6(6.0) that the heads were milled .40 ths the compression should be between 10.5 to10.8 the cam I was going to use is compcams lsr 269 219/227 .607/.614 on a lsa 112 how will this run
You need to match it up with a good aftermarket converter as well. Might want to get gears later on too, depending on what you already have and if you have a heavy truck with heavy wheels/tires.
PT's Slowest Truck
Once tuned, it should run really well with a fairly broad powerband, and will also work well with your Circle-D 3200. Do you have anything else done to the heads? I wouldn't let that .6xx lift go to waste, and get a nice port and polish or CNC job. If you have the dough, you should give Richard at WCCH a call and discuss your options
lxcoupe
07-27-2015 08:19 PM
