How would these work for a baby cam?
PT's Slowest Truck
I like making people think.
I would think 2.5" collectors would be better for a mild 5.3 to help keep the low end torque? Most people don't run 3" true duals they run 2.5". IIRC a 3" single is good to about 450-500hp? I would think 3" collectors would just cause a loss of exhaust velocity but I could be wrong.
I was thinking 113LSA would be a nice medium between the common 112 and 114 but IDK. This thread is merely me thinking out loud because I'm bored and can't do anything with a broken collar bone.
With that being said, I'm gonna get a little off topic The 2.5 collectors actually work perfectly with my current setup (mods in sig), but I have an LQ9 shortblock that needs a freshen up and some WCCH StageII 317's ready to go on after a little milling (maybe .030 -.040), and that's the direction that my minds going when I'm thinking of cam specs
I like the 113, like you said, if you can't decide on 112 or 114, split the difference . Seems like guys have had good results with GENIII's with 111, 112, 113, 114, 115,etc...it all depends on the combo
Originally Posted by Doc_speeder
So I went to Isky's website, the cams in the LS catalog are all split pattern...
Maybe they designed them for newbies who want to throw shorty headers and a cam on their truck? Or maybe split pattern cams just tend to sell better, who knows?
People seem to have good results running the TR or TSP 220 and 224 I'm just kinda curious how it'd work in bigger and smaller packages. Like would the 212/212 be better than or comparable to a low lift 212/218?
9 Second Truck Club
In the larger cams the single pattern is often the way to go in a heavy truck, but in cams below 218 @.050'' I like to run a short split in most NA applications, especially when running cats. Often times you can get away with less exhaust duration as LSA tightens, but opposite is true when center increases due to the reduced scavanging effects. If you are running headers and good exhaust system you want a tighter lsa, and single pattern, to low forward split. When running exh manifolds or shorty headers the tight LSA and single pattern can hurt you... A ISKY 212/215 112 would work well in most applications. I wouldn't go past 112lsa unless you are running stock manifolds, or shorty headers. JMO
so with some exhaust restriction (ie cats, shorties, manifolds) you want a small split pattern
but with an open exhaust (longtubes ORY) you want single patterns and a tighter LSA
smaller lsa you can go less exhaust duration
what do you mean when center increases?
when you say go past 112 LSA do you mean higher or lower?
sorry if I seem like a
ARC
57
02-21-2022 10:54 AM
Castro45
24
07-31-2015 07:13 PM
