i have a problem,and need help,with a ratchet extension,stuck in the crank
Old 09-07-2011 | 03:14 PM
charcold-bowtie's Avatar
im pretty sure its stuffed into the crank.Theres no pulley or bolt on there
I did that will pulling a crank pulley off my old 4.8 this summer lol. Luckily I have no plans to use mine. IE, my pulley puller wasnt long enough and i didnt have a crank bolt
Old 09-07-2011 | 06:12 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by AKlowriderZ71
I'd guess that the threads in the crank are already messed up a bit. But they'll probably clean up.
I'd get a slidehammer, and weld a nut onto the extension that you can grab with the slidehammer. Load the crank/socket extension with penetrating lube, and go at it.
If it breaks off in there, grab a center punch, mark it dead center, and drill out the broken piece. Start small, and work your way bigger a little bit at a time.
This is what I would do...slidehammer for sure
Old 09-07-2011 | 06:22 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Copycat...
Old 09-07-2011 | 06:58 PM
Mangled03gmc's Avatar
Baltimore Whore
Look you guys are all copying of what I would do..
Old 09-07-2011 | 07:14 PM
Or, the OP could just call Chuck Norris. Once the extension knew Chuck was coming, it would fall out of the crank & apologize for causing so much trouble.
Old 09-07-2011 | 07:19 PM
Baltimore Whore
Old 09-07-2011 | 10:04 PM
1slowz71's Avatar
LMAO...........................
Old 09-08-2011 | 12:51 AM
budhayes3's Avatar
PT's Slowest Truck
Wait, I change my answer, I'd call Chuck Norris instead of the slide hammer!
Old 09-08-2011 | 12:54 AM
1989k1500's Avatar
LOL, half you guys are missing the part about it not being a socket.
Its an extension, jammed inside the crank. Its not a socket stuck on a crank bolt.
Im guessing if its in there that good the threads are probably a little fucked up inside the crank.
Old 09-09-2011 | 01:01 AM
Yep, I understood the problem, and agree that the threads are gonna be marred up a bit. But it's probably only the first 1/2" or so, and he could run a tap through it to clean it up.
Chuck Norris has probably already fixed it by now anyways, that's why this thread is dying.....
