I have a theory (check my logic)
#42
Originally Posted by thunder550
kbracing96 ran a 12.79 @ 105 with his 4.8L STS 4x4 ECSB, 210/218 cam @ 12 psi
So i thought it over and here is how i may go after i make some phone calls today.
Iron Block 5.7L
Forged Internals (9:1 Comp)
Trick front mount turbo
Gearing undecided
Keep my 3200RPM converter
Keep the FLT or get it upgraded to a Level 5
#44
The LS4 and L33 use the same cylinder heads and the same pistons. If I were going to build an engine to do what you're doing, I'd get an L33 and use LM7 cylinder heads with bigger intake valves installed and ported. That will bring your compression up. The stock lower end is just fine, just change the rod bolts. All of that with the right cam and a better intake manifold is about the best you can ask for without spending more than it's worth to get your goal.
#45
thanks Zippy, i think i may go boosted cause thats like crack. but i have to call some suppliers. i have to call and talk to richard and then trick and then i have to find someone to build the 5.7
i think i may slap a turbo on my 5.3 and start the new motor fund and when its full i'll turn up the wick and see what she'll do.
#46
how about this 5.3 486hp/425tq
https://www.performancetrucks.net/fo...d.php?t=386962
direct
http://www.racingjunk.com/post/82332...ip-Engine.html
direct
#49
Originally Posted by TurboBerserker
I'm a bit confused here. Why put another stock crank in? Just change your pistons to either some forged flat tops (or stocker GM flats) and possibly go to some high spin rods.
Apologies if I've missed the point
