I know that in 05 the rods on the lq motors changed??
Old 08-17-2009, 06:18 PM
Baltimore Whore
Mangled03gmc's Avatar
Originally Posted by StrokerAce03
It was the LQ4 as well. Cranks stayed the same.
So we all are sure that the only thing that changed in them 05 and after is infact the rods??? Not the cranks...
Old 08-17-2009, 06:36 PM
Mr. Obvious
nightrunner's Avatar
after 01 they changed the crank on the iron block 6.0 truck enignes. all lq4/lq9 after that have same crank. in 05 they put LS2 rods in all 6.0L engines (ls2/lq4/lq9) as they are stronger.
Old 08-17-2009, 06:41 PM
GMCtrk's Avatar
technically they are LQ9 rods, not LS2 rods, since they were first used in 2002.
Old 08-17-2009, 06:43 PM
dlt76028's Avatar
Negative.. 370 will be plenty
your going up a whole 6 cubes... WEAK SAUCE
Old 08-17-2009, 06:53 PM
Baltimore Whore
A 370 will be plenty for what im looking for, wasn't a big subject not long back about a 370 vs 408, the lil diff in hp output when boosted??
Good so I am rolling with this crank...
Old 08-17-2009, 06:56 PM
GMCtrk's Avatar
the 370 is more reliable. no need for 408
Old 08-17-2009, 07:00 PM
Wearin' da big hat
00ChevyScott's Avatar
Old 08-17-2009, 07:01 PM
dlt76028's Avatar
if its a brand new engine I don't really see a difference in reliability?
And John, I was just giving you a hard time.. you putting the procharger back on?
Old 08-17-2009, 07:05 PM
GMCtrk's Avatar
In that case, I suggest you do a bit of reading. There's a real good thread on this very topic if you do a search.
Old 08-17-2009, 07:07 PM
Truckshop's Avatar
no need for a stroker if ya gonna run boost. IMO.
Quick Reply: I know that in 05 the rods on the lq motors changed??
