I Need Valve Spring Suggestions
#24
It's cutting it close, but if he already had the springs I can see why he's running them.
#27
The 317 heads use the same valves (minus the sodium filled ones) as the LS6, which I believe are 2.00 I and 1.55" E. So I would say any spring meant to fit the LS6 (243 casting) will fit your 317 heads. I've tried finding the spring pocket diameter on the 243s and I can't find it. Perhaps someone else can chime in, cause I'd like to know this as well considering I have them on my truck.
The LS1 (241 casting) heads have a 1.63" dia spring pocket however, I managed to find that one.
#29
Really? where are you seeing this listed, because I only see OD and ID listed for these springs and even ID are much bigger than either .505 and .565"
http://www.pacracing.com/Beehive_Spr...Set_of_16.html
http://www.pacracing.com/Street_Stri...Set_of_16.html
http://www.compperformancegroupstore...Category_Code=
It's possible those smaller diameters are the measurements of the top coil of the beehives?
#30
For instance the pat golds, http://www.jegs.com/p/Patriot-Perfor...22045/10002/-1
There are 2 different sets for the different spring base sizes.
