Intake maifold probs
Registered User
This is the problem,I want to eventually run forced air on my '98 L31 5.7. The stock intake with 19lb hour injectors and the way they run inside the maifold is a limiting factor, I have heard that either a marine intake or a Ramjet intake setup would solve my problem. I need to know if either of these will solve my problem and if they will plug right into my harness. Also any sugg as to where to purchase... thanks guys.
I am running EV6 injectors in my marine intake. They flow 24pph at 43.5 psi which actually flows 28.3pph at the vortecs 60 psi of rail pressure.
Here is all the info.
marine intake
http://www.pacificp.com/forum/viewtopic.php?t=317
a twin turbo ramjet intake with GEn 3 411 PCM.
http://www.pacificp.com/forum/viewtopic.php?t=3240peace
Hog
marine intake
Hog
Pontiac Derek
09-19-2015 01:49 PM
